With delivery of a 90 degree drill and bit set from Aircraft Spruce I was able to drill out the rest of the rivets attaching the reinforcement angle and splice angle from the HS main spar. Then I prepared the doubler plates and rib flange angles. The doublers were drilled to the spar and angles, then removed, deburred and primed.
