First I replaced the temporary prop supporting the center of the spar with a jack stand purchased at Home Depot, and recheked the level of the spars. Then I match drilled the tops wing skins. Next I clecoed the bottom skins to the skeleton and then match drilled them. Finally I assembled the leading edge cradle in preparation for the next session. I know things will slow down again soon but it sure is fun to see large components like the wing take shape so quickly during this stage!!
