Dimpled rear spar pieces and riveted spar reinforcement bars to spars. The pneumatic squeezer makes quick work of these rivets but can also make quick work of a bad rivet if not aligned properly. 92 rivets set, 5 needed to be drilled out an replaced. Hopefully I am still on the learning curce for the squeezer.
