Larry and Eddie - Sportsman
Date:  5-18-2012
Number of Hours:  3.00
Manual Reference:  55, Systems
Brief Description:  Drill Holes in Root Rib for the Main and Return Fu
Refined the hole in the Lower Wing Skin for the Main Tank Sump Drain Boss. Used clay and awl, as per the method used in step 54, to determine position of main and return fuel line bosses with relation to root rib. After drilling pilot hole, used 7/8" and 1" hole saw in drill press to create holes for main and return fuel line bosses.
Clay and awl
Clay and awl
Clay and awl
Clay and awl
Preparing to drill pilot hole
