Brief Description: Apply Anti-Chafe Tape to the Hat Section Stiffener
Apply Anti-Chafe Tape to the Hat Section Stiffeners in the Fuel Tank Bays
First sprayed lower hat sections with a protective zinc primer to prevent corrosion or oxidation in any areas that required a coating. Then applied anti-chafe tape to each lower hat section.
