Martin's Web Site
Date:  3-20-2016
Number of Hours:  8.00
Brief Description:  Left Wing tip fairing; SB06-2-23
Continued with fairing the left wing tip. Working on the bottom side. There were 2 "oil-canned" areas. The forward one was small enough that I could fill it with epoxy and microfiller. The aft one will require a rib or filling the internal cavity with foam. I also opened the fuel tank, scrubbed the proseal off the opening. I removed the flop-tube and safety wired and dimpled it per the SB. I also ordered some proseal and new tank gaskets.
