Installed floor stiffeners. The alignment of the center stiffeners was not perfect, especially wrt the F601J firewall angles and F783B cover support ribs. In the end, because of the pre-drilled skins, I had to apply shims between the center stiffener angles and the F601J's in order to get a tight joint. These will now require longer rivets than what's called out in the plans.
