Fab'd the rudder pedal brace and mounted to rudder tubes using F6115 center bearing block. Drilled and clecoed brace to firewall stiffener and then match drilled w/ center bearing block in the 3 corresponding positions. Note: the farthest aft position did not fit easily and I may want to create a new center bearing block if I decide to mount the pedals in this position.
