Riveted stiffener and hinge brackets to rear spar using squeezer. Then riveted ribs to front spar with squeezer. Had to use 125 psi to get 4-7's and 4-6's to set properly. Otherwise 80 psi worked fine. Finally, clecoed skin to forward spar in preparation for riveting.
