MRB's - RV-14 Build log
Date:  12-19-2015
Number of Hours:  2.50
Manual Reference:  Sec 18
Brief Description:  Fuel Tank Assembly
Now is a good time to apply a filet of sealant to the fuel tank cap flange and especially the bottom tank stiffeners. Once the tank ribs are in place, applying sealant around those parts will be far more challenging due to limited access.
As a note, each 20cc syringe allows for a 30g batch of sealant. Filling a syringe (using a popsicle stick) is a bit awkward at first but you get the hang of it after a few batches. The first try make you feel like digging snots in your nose wearing a boxing glove … Also, I once tried to fill a syringe with 40g but that volume would barely fit in the tube and I ended up crating a mess so 30g is the key number here.
Filet of sealant arounf the fual cap flanges.
Filet of sealant around the tank stiffeners.
It took nearly 250g of sealant to seal out the stiffeners and all the other tank flanges
