MRB's - RV-14 Build log
Date:  12-16-2015
Number of Hours:  4.50
Manual Reference:  Sec 18
Brief Description:  Fuel Tank Assembly
The goal for this work session was to final install all the numerous fuel tank flanges (drain, fuel cap, inlet/outlet, vent) found on the tank skins and the inboard ribs.
At first I thought that I could simply use the hand squeezer to set the rivets all over the place but soon realize that things would not be that easy. In fact, I came to a hair ruining the left wing fuel tank fuel cap flange. Once again, I managed to recover my goof and fixed the thing in an appropriate manner. In a nutshell, setting the rivets on these parts boils down to a combination of hand squeezer, DRDT-2 tool, back riveting with a gun and… patience.
Riveting all the fittings to the T-1003B ribs
Fuel cap flange was riveted using the steel backplate
Inside view of one of the fuel cap flange with the vent line clip installed.
