Brief Description: Priming the Flaps and Torque tube support bracket
Time to prime these parts prior to installation. I have previously scuffed all the parts with a 3M scuff pad (grey). Then I spray an acid etching solution (Eko Etch) over the parts that I scuff again with a pad. The part is then rinse out in fresh water and left to dry. I finally wipe clean each part using MEK or acetone to promote primer adherence.
