RV-7A Tip-up QB build project
Date:  12-9-2011
Number of Hours:  10.50
Brief Description:  Worked on all glass tips and fairings
Work begun on all the fiberglass tips and fairings, starting with the rudder top and bottom, then the Hstab top fairing. Trimmed, fitted, re trimmed and fitted, filled, sanded, primed and shaped to fit. match drilled and cleco'd in place for fional drilling. Also some work on the empennage finishing, dents, scratches buffed out and the balance weights removed and re assembled and adjusted accordingly to fit the fairing tips.
Hstab Right hand tip 1.
