RV-7A Tip-up QB build project
Date:  6-27-2012
Number of Hours:  9.50
Brief Description:  Canopy frame, Parts prep&prime, Static bracket add
Started individual cleaning, edging, straightening, prepping and priming of all canopy frame components.
Mass prime of all parts to be painted to match interior, plus all parts to be worked with in the current chapter were prepped and primed with a big batch of primer mixed up.
Certain applcable parts primed were then final coated in yellow.
Sought a solution for the static line intersection and made up a bracket which failed but then used another hardware bracket and installed in the cabin on the longeron which solved the issue.
Cleaned and turned the latch handle knob as supplied, fitted and drilled and installed on handle.
