Brief Description: fitted the canopy bubble and re marked and located
Riveted the hinged shroud assembly together with the skin still cleco'd in place to keep it'shape, had to mnaufacture jigs from wood to fit in the joint and clamp the assembly in place. fitted the canopy bubble and finalize the location with many measurements and references, then re measuring and rechecking. Once happy I marked the line for the cut and applied new masking in preparation for the cut. assembled the table outside for tomorrow's cut and tested a small cut on the excess plastic on the bubble's edge as per the manual's suggestion. Spenmt some time in communication with avcommers regarding this cut. Spent approximately 45 minutes collating photos and compiling this week's log. Only stopped work at 9pm.
