Brief Description: Forward deck final dissasembly and re installation
took apart the front deck assembly for the final time to prime all the ,matching surfaces then final drilled, deburred and dimpled the applicable holes for riveting. re assembled the entire assembly and began riveting part by part. Also made up F-697 channel and primed then clamped in place on sub panel then match drilled and cleco'd in place. Also mad eup and fitted the forward fuselage channel F-643-1 following the same process of clamping, match drilling, processing the holes and cleco for riveting.
