Brief Description: Began work on the Right wing tip....
Having again missed a Monday due t personal difficulties I picked up work on the right wing tip - having run out of platenuts to finaish the left tip (on order). I began by drawing up and then cutting and trimming and sanding a tip rib in dense foam as per the right wing.
The rib was fitted, adjusted and epoxy bonded in place then clamped to cure overnight. I also too the time to remove the control surfaces and fittings on the left wing so that they can go back to the paint shop to be finalized before storage and so that the wing can be put away and the right wing put on the table.
