Brief Description: RW - Conduit final installed wing skin re riveted.
The proseal having cured and the joins sound I final installed the conduit as mentioned by stretching between fasteners at the end ribs and securing with sleeves and a silicone wrap - happy that the installation as it is now will be lasting and endure much abuse and flexing etc.
Having repaired the wing I again began the riveting of the skin in place finally, in the previous installtion however I had encountered some serious reach issues doing it from tip to root and with a row of rivets already set in the root end I worked from root to tip the more conventional method as foll.owed on the Left wing which worked well.
Again the tediousness of wing skinning solo made this task less than enjoyable and also made for a slow pace, but with the new mushroom head I am getting good sets and clean, neat results.
