...more riveting on the LW, finished 90% of it today and got super results with the new swivel head. Marked out all the bad or ugly set rivets on the wing for either buffing out or filling...most require only buffing but 4 or 5 will need to be filled and I may need to drill one in particular and re set it.
Also, with the instructions to finish by Friday I did some work on the matching wingtip including cutting and fit of the lens cover(fitted but has to be final trimmed), drilled and fitted the nav light unit as per the Right tip and installed the trailing edge rib/fillet as per the Right.
