Brief Description: Re-installed empenage, Panel research and template
Having installed the V-stab in place and fixed the attach plate (see 18th Nov) I final drilled the attach plate bolt holes to the stab spar and then installed the final bolts and nuts and torqued accordingly, also final installed all stab post bolts (correct bolts) and torqued. Just before tightening the V-stab the H-stab was loosened and then re-aligned and empenage was aligned and measured for square and position and incidence, all bolts tightened, re-torqued and safety'd final. Empennage is now 100% complete. Discussed panel layout with Willem and drew a revised layout on the actual part F-703 to scale.
