Brief Description: Canopy masked, fitted, Painted all canopy frame pa
Continued washing, cleaning and dusting the outside of the canpy bubble then dried and began applying film/clingfilm as advised and in overlaps with particular cover of the leading edge and apex of the bubble. When that was completed the bubble was safe to work with and protected so I re-fitted and got proper alignment again and marked the cabin and roll bar accordingly.
I installed the canopy frames on the bubble and with clamps made up the canopy assembly based on the now hinged in place canopy deck. Necessary markings were made before I fitted the rear glass and got it's location based on the fitted main bubble and frame, necessary markings were made and it was all removed again and the plastic stored safely.
Also began prepping then laid out and began final-coating the silver parts of the canopy, canopy frame and latches so that they can be final assembled and installed.
