Brief Description: More work to fix the map box, Half the day spent o
further work to shorten the mapbox even more since it wasn't fitting properly, also revised the structure of the box to make for a neater interior and stronger overlaps. Deburred and rounded all edges and corners then built the box and match drilled for rivets.
-see 'NON-BUILD HOURS' for the rest of the day's logs.
