Brief Description: Paint, sealant, and some wiring
Last day before we go back to work and Kevin and I found some time to work on the plane. First thing we did was prep for the interior light and run wire for later use. Then we took on paiting parts for the interior. Finally we started sealing the firewall. Vans is not real specific about what to use and says Proseal is fine. We went with same ultra high temp silicone we have used before. Only down side is that it is a burnt orange in color. Will seal; the rest of the rivet as things go along.
Plan is to finish up the painting and next weekend do the wing fit.
