Dans RV8
Date:  1-11-2013
Number of Hours:  1.00
Brief Description:  Prop Governor Adapter
I designed a simple prop governor adapter. This will give me some meat to mount the VA 153 at just the angle I want. I will come over the top of the engine as Van's did. It is a pretty straight shot.
I will use my CNC machine to fab a sample out of aluminum. Once the fit is right, I will cut the actual unit out of cold rolled steel.
