The Oil Pressure pickup is in a very bad location. I can't get the hose on the nipple due to interference with the motor mount.
I want to swap the nipple with the plug circled. Unfortunately, I can’t turn the nipple – it hits the motor mount when rotated 180 degrees. One way to remove it is to pull the engine – at least a few inches. The other alternative is to fill the nipple with hot melt or similar, then saw off the angle part. Remove it and put a new one where the plug is. I will do some checking on this.
Van’s tells you to put the nipple in before mounting the engine. But I don’t see any way to get a fitting on it. Even if I could, it would be a pain in the future.
