I put the two halves on the wings, aligned the two halves to have the proper difference in elevation, marked and drilled the holes and installed the flaperons.
At this point, I’ve done all I can do at home. In the Spring, I’ll take it out to the hangar for final assembly. It should go fairly easy since the entire plane has been assembled in my basement (famous last words). We’ll see.
