I plan to run 3/8 in. Alum. tubing from the fuel tanks to the firewall. I started with the right side and used a 90 deg. bulkhead fitting through the top of the fuselage into the vertical channel just forward of the baggage area. Ran that line and covered it with rubber tubing since there is no way to use clamps to secure the tubing. Put another 90 deg. bulkhead in the floor and ran the tubing to that fitting. The plan is to run the fuel lines underneath the airplane. The fuel lines would come up through the floor into the center console and connect to the selector valve. From the selector valve, I would run 3/8 in tubing to the firewall. Had to stop and order additional AN fittings.
