Started assembling the Jabiru 3300 engine (with solid valve lifters). It was dissembled and partially repaired in the A&P school at BlueRidge Community College in the Spring. The class as long finished and Greg is nice enough to help me reassemble the engine. The third set of pistons arrived and we assemble the rings on the pistons and put the cylinders on the block with the proper piston in each cylinder.
