CHUCK'S WEB SITE
Date:  6-11-2022
Number of Hours:  1.90
Manual Reference:  SNB-G01
Brief Description:  Bulhead And Tank Fittings
Removed fuel tank. Drilled and mounted fuel line bulkhead fitting. Drilled 3/4" hole (may enlarge to next step drill size) in glare shield for fuel vent fitting.
Reinstalled tank to verify vent fitting fit through the hole with adequate clearance. Removed the tank and flushed it with water multiple time to clean interior and remove all plastic drill shavings.
Interior side of fuel line bulkhead fitting.
Engine side of fuel line bulkhead fitting.
Fuel vent fitting clearance hole in glare shield.
