Brief Description: Control Stick Completion And Seat Belt Fitting.
Completed the control stick assembly. Tapered hole for stick tube to control stick fitting. Lubed all bushings from control stick assembly to pushrod idler assembly and set all castle nuts and cotter pins.
Fit seat belts to seat pan opening. Had to reposition how the seat belts were fastened in the center console and widen the slots in the seat pan for the seat belts to come up through in the middle.
Finished control stick assembly with wiring harness for stick grip routed through hole in fitting.
Seat pan seat belt slots widened to prevent edge abrasion/wear on belts .
COntrol stick and seat belts mounted with seat pan clecoed in place.
