CHUCK'S WEB SITE
Date:  2-3-2022
Number of Hours:  5.75
Manual Reference:  SNB-T01 & SNB-C01
Brief Description:  Final Tail Mounting Adjustments - Completed.
Continued with final tail mounting adjustments and control rigging for for tail surfaces. Finalized clearance for elevator push rod connection to elevator horn control arm. All skin trims adjusted as needed for final bolted down position.
Drilled and bolted on he tail skid plate mounting tube.
Final clearance through arched bulkhead opening.
Final elevator push rod to elevator horn bolt and bushing linkage fitting.
Bolting on the tail skid mounting plate.
