Brief Description: Final Tail Mounting Adjustments - Continued.
Continued on final tail mounting and control adjustments. Seems to have achieved full 25 degrees up elevator deflection. Trimmed elevator horn control arm tip to strike flat against the additional stop plate for up elevator deflection stop.
Started making clearance for elevator push rod to eliminate any contact in empenage section.
Slightly heightened arch opening for elevator push rod clearance.
