CHUCK'S WEB SITE
Date:  2-12-2022
Number of Hours:  3.40
Manual Reference:  SNB-C01 & SNB-L02
Brief Description:  Completed Rudder Controls Rigging w/Nosewheel.
Fit and connected rudder left and right rudder cable adjusters. Rigged pedals for lower bars even all the way across the pedals and the rudder at neutral. Trimmed and radiused both cable adjusters and reinstalled.
Sized and installed both rudder return springs. These needed to be shorter on the attachment. Basically just a looped coil at each end of the springs, not an 1.5" length straight piece for attaching.
Adjusted bearing position on threaded end of the nosewheel steering push rod on the steering linkage from the rudder pedals to the nosewheel. Set so the nosewheel is straight when the rudder pedals are even and rudder is neutral.
Trimming and radiusing the cable attachment end of the rudder cable adjusters.
Control rigging for control stick to elevator and rudder pedals to rudder and nosewheel completed.
Tail permanently mounted with both elevator and rudder controls rigged.
