Trimmed skin on vertical stabilizer to attach and fit to horizontal stabilizer. Got all trimming done, with a good straight vertical spine in the rear and proper skin to fuselage clearance, and clecoed it fully secured.
Vertical stabilizer appears to be in place per plans specs.
Elevator up travel has decreased after fitting the VS. Will not mount anything until this is resolved through Kerry & Sonex Tech Support.
Trimming skin back to the tape line.
Vertical stabilizer installed and clecoed in place.
Vertical main spar straightness before and after skin trimming and fitting.
