Started to try and mount the Motor Mount (SNB-P10) to the firewall, but due to very restricted access, ended up falling back to remove all temporary rivets (marked red) to remove the tailcone belly skin, instrument panel, glare shield, and seat pan first.
Also noted the AN5-35A bolts (2) called for to mount the lower 2 motor mount firewall attachments were too long. No bolts in hardware kit that were proper grip length for the slightly shorter bolt requirement for the upper two firewall attachment points.
Got tailcone belly skin completely removed and stowed. Worked on drilling out temp rivets on glare shield.
Belly skin, seat pan and glare shield removed for easier access.
