Brief Description: Blister Interior Fiberglass Reinforcement - Part 2
I repeated the process as documented in Part 1 to lay up two layers of fiberglass cloth tape reinforcement over the remaining aft and forward sections of the blister channel mounting. The internior ended up with a reasonable smooth and contoured fiberglass cloth reinforcement lay up around the entire perimeter of the blister channel mount.
Will allow this to fully cure at least overnight and move on with the exterior joint reinforcement.
Two layers of fiberglass cloth tape at the rear area of the blister attachment.
Two layers of fiberglass cloth tape at the forward attachment area near the prop hub.
Final two-layer fiberglass lay up reinforcement to the interior blister attachment.
