Brief Description: Installing Cylinder Head Temperature Sensors
Marked both pilot and passenger side plug wires for proper position.
Installed all six (6) cylinder head temperature sensors under the exhaust side plugs. Have not yet centered and tightened the plugs to the proper torque. Need to look the torque value up before completing the sensor installation. Also need to order a replacement spark plug terminal nut for exhaust side spark plug on cylinder number 1 (labelled R1 in passenger side photo).
Then, all snesors can be properly centered under the spark plugs, and the plugs tightened to the Jabiru specified torque values.
Pilot side plug wires marked and cylinder head temperature sensors installed, but not torqued.
Passenger side plug wires marked and cylinder head temperature sensors installed, but not torqued.
