CHUCK'S WEB SITE
Date:  2-12-2023
Number of Hours:  2.30
Brief Description:  Final Mounting/Fitting Of Displays & Control Panel
Fit all four center mounted mini-panels, then fit the two 10" SkyView HDX displays.
With the exception of the ELT test panel, the instrument panel with Carbon Fiber overlay is completed. However, the two final mounting trays still have to be made from the heavier gauge 6061 T6 aluminum.
The final order for the remaining avionics components is being placed with AFS/Dynon.
The four center mounted mini-panels fit.
Rear view after all available panel components have been fit and mounted.
Combo view of final panal (except ELT panel) from front and back.
