CHUCK'S WEB SITE
Sonex-B Tri-Gear
SNB-F08
Making SNB-F08-02 Seat Back Assembly
Made 2 each SNB-F08-05 (Hinge 1) and SNB-F08-06 (Hinge 2).
Made 4 each SNB-F08_07 Hinge Pins.
Layed out position lines on seat back stock sheet. Positioned Hinge 1 and Hinge 2 on top and bottom edges of the seat back stock sheet.
Drilled all #40 pilot holes into the seat back per the hinge holes. Clecoed hinges into proper position.
Updrilled all #40 holes to #30 size, and reclecoed with #30 copper clecoes.
Dissassembled both hinges from the seat back, deburred, and re-assembled with #30 copper clecoes.
Riveted both hinges into final position with CCP-42 rivets, completing the SNB-F08-02 Seat Assembly.
Using the ruler template to layout and quickly drill the hinge stock.
Final riveting of the hinge to the seat back.
Completed SNB-F08-02 Seat Back Assembly.
Sonex-B Tri-Gear Home
1153
142
Cowling
66
140
Documentation
69
81
Electrical System
232
Plans Review
