Adjusted the trim on the vertical stabilizer skins for final fit.
Scooped a small amount of clearance relief in the forward strap of the vertical stabilizer main spar to allow the elevator horn control arm weldment to clear it when the elevator is rising.
Rounded out an area of clearance in the vertical stabilizer skins on the left and right sides where the elevator horn cross bar was striking the skin edges and stopping travel. Deburred all trimmed skin edges.
Drilled, deburred and added one rivet on each side to replace the rivet removed when trimming the skins for elevator horn cross bar clearance.
Elevator horn cross bar in the elevator full-down position.
Elevator horn cross bar in the elevator full-up position.
Elevator horn cross bar in the elevator full-up position. Note the new rivet just forward of the bar.
