Brief Description: Control Stick Assembly - Continued.
Worked on a drillpress jig to accurately drill pilot holes through SNB-C04-07 control stick fitting and steel pipe in proper location per the plans. Drilled hole to sizes to size and then manually tapered with #2 taper reamer for the taper pin.
Completed main control stick assembly, less the single grip stick tube, which is on backorder.
Hand taper reaming the hole for the larger taper pin.
