Brief Description: T10/T08: Assemble Vert Stabilizer Assy - Part 1
T10: Collected all required parts and cut hinges to specified length and dressed hinge end cuts. Plans page T10 completed.
T08: Pilot clecoed Upper Hinge to Main Spar Assembly. Assembled full Vertical Tail frame, connecting Main Spar Assembly and Forward Spar Assembly with specified tail ribs.
Drilling pilot holes to final size to attach the forward rib ends to the Forward Spar Assembly.
Vertical Stabilizer Assembly frame assembled, with Upper Hinge pilot clecoed in place.
