Chris' Web Site
Date:  9-17-2021
Brief Description:  Mount the ECU Bluetooth Adapter
Plans:
1. Mount the ECU Bluetooth sender.
Status: Complete. The little Bluetooth sender that broadcasts the ECU signal to the cellphone on the instrument panel has been lying freely on the floorboard. I created a little mounting bracket that secures it to the side panel. The cable from the engine and the adapter were joined together with a panel mounting faceplate from Amazon. After running the engine I found that it vibrated quite a bit. So the top end was also secured to a small backstop with a cable tie.
ECU Bluetooth Mounted
Sandwich Plate Panel Mount
Improved Mount
Improved Mount
