Craigs RV-8 Web Site
Date:  7-22-2018
Number of Hours:  2.75
Brief Description:  Lables
For the switch labels I used a product from Pulsar FX called Decal Pro. The product had a steep learning curve, you definitely have to follow the instructions to the letter and work small.
I do have to say once you get the hang of it it works very well. The labels only take a few minutes to make up, are pretty durable but if you need to remove one, alcohol and some rubbing will remove them.
Flaps and Boost Pump
Starter and Battery Master
Switch Console
Switch Console
