Craigs RV-8 Web Site
Date: 11-5-2017
Number of Hours: 6.00
Manual Reference: 8s8PP-1 r1 06/23/1
Brief Description: Baggage Door
BAGGAGE DOOR
Page 8-70
Made two F-873K Latch Pins as shown in “F-873K Latch Pin”, DWG 84.
Smoothed and deburred the edges of the F-873L-1 Lock Arm
Deburred the edges of the F-873E-1 Baggage Door Outboard Rib, F 873F-1 Angle, F-873B-1 Baggage Door Fwd Rib, F-873C-1 Baggage Door Aft Rib, and F-873A-1 Baggage Door Skin (“Baggage Door Exploded View”, DWG 84).
Clecoed the F-873E-1 Baggage Door Outboard Rib, F-873F-1 Angle, F 873B-1 Baggage Door Fwd Rib, and F-873C-1 Baggage Door Aft Rib to the F-873A-1 Baggage Door Skin (“Baggage Door Exploded View”, DWG 84).
Clecoed the F-873D-1 Baggage Door Inner Skin to the F-873E-1 Baggage Door Outboard Rib, F-873F-1 Angle, F-873B-1 Baggage Door Fwd Rib, and F-873C-1 Baggage Door Aft Rib.
Enlarged the tooling hole at the outboard end of the F-873B-1 & C-1 Baggage Door Ribs (“Baggage Door Exploded View”, DWG 84).
Final-Drilled #40 all the 3/32 holes common to the F-873A-1 Baggage Door Skin and substructure.
Final-Drilled #30 all the 1/8 holes common to the F-873D-1 Baggage Door Inner Skin and substructure.
Cut the F-873J Hinge to size as shown in “F-873J Hinge”, DWG 84. Clamped the F-873J Hinge in position as shown in “Baggage Door Aft View”, DWG 84.
Match-Drilled #40 the holes in the F-873A-1 and F-873F-1 Angle into the F-873J Hinge.
Deburred all the #30 and #40 rivet holes in all the baggage door parts. Dimple countersunk all #40 rivet holes in the F-873A-1 Baggage Door Skin for flush rivets on the exterior surface.
Dimple countersunk the #40 holes in the F-873E-1 Baggage Door Outboard Rib and the F-873B-1 & C-1 Baggage Door Ribs.
Machine countersunk the #40 holes in the F-873F-1 Angle.
Dimple countersunk the #30 holes in the outboard flange of the F-873D-1 Baggage Door Inner Skin and the corresponding holes in the F-873E-1 Baggage Door Outboard Rib.
Primed the baggage door parts.
Back riveted the F-873E-1 Baggage Door Outboard Rib to the F-873A-1 Baggage Door Skin (See DWG 74).
Match drilling holes
Dimple countersinking
back riveted outboard skin
