Installed the parking brake cable. The cable activated the parking brake hydraulic valve as well as a micro-switch. The micro-switch is connected to an indicator in the instrument panel. The indicator is wired to the NC side of the micro-switch so that the indicator will not turn off unless the parking brake valve is in the fully open position.
