Craigs RV-8 Web Site
Date:  10-24-2011
Manual Reference:  8s8-1r1 12/02/08
Brief Description:  Elevator Control System
Page 8-57
Primed the inside and outside of the pushrod
Threaded the rod end bearings and adjusted the overall dimension
Constructed the F-840 push rod assembly. Installed rod end bearings on the F-840 pushrod assembly and adjusted the overall length
Installed rod end bearings on the F-839-2 pushrod assembly and adjusted the overall length.
Final drilled the 1/4 inch holes at both ends of the WD-807 control column
Final drilled #12 the rod end bearing holes used to attach the control column to the F-849 forward control mount and F-837-1 aft control mount
Final drilled #12 the holes used to attach the W-816 aileron pushrod assemblies
Filed and shaped the bushings and filed the tubes that sleeve the bearings to size
