Brief Description: Elevator Servo and Strobe Power Supply Mount
Fabricated a mount for the Trio Avionics Gold Servo Fabricated the servo mount from a design supplied by Trio Avionics. The design was modified by increasing the size of the top plate to allow for mounting the Weilen power supply. The top plate was fabricated using .035 2024-T3. Installed K1000-03 nutplates in the left and right longerons for AN-3 bolts to fasten the assembly to the aircraft structure The Servo and Strobe power supply are attached to the assembly using AN3-5A bolts.
