Craigs RV-8 Web Site
Date:  8-2-2011
Number of Hours:  1.00
Manual Reference:  8s8-1r1 12/02/08
Brief Description:  Seat Floors
Page 8-48
Clecoed together the F-830-1 left seat floor and the F-831-1 right seat floor using the holes common between them as shown in seat floors drawing 77.
Separated the F-830DEF-1 floor stiffeners into two F-830D-1, two F-830E-1 and two F-830F-1
Smoothed and de-burred the floor stiffeners
Cleco'ed the 3 F-830C-1 floor stiffeners in place on the F-830-1 Left seat floor and F-831-1 right seat floor.
Cleco'ed the four F-830B-1 floor stiffeners in place on the F-830-1 left seat floor.
Page 8-49
Clecoed the F-830D-1 and F-830E-1 floor stiffener to the bottom of the F-830-1 and F-831-1 seat floors
Removed the F-830B-1 stiffener common to the rear seatback hinge
Clecoed the F-833D-1 rear seatback hinge into position on the F-830-1 left seat floor (Drawing 77)
Match drilled #30 the 3/32 holes into the seatback hinge
Removed the F-833D-1 rear seatback hinge from the F-830-1 and F-831-1 seat floors
Final drilled #30 the 3-32 holes in the F-830-1 floor stiffener that is common with the holes that attach the F-833D-1 rear seatback hinge
Final drill #30 the 3/32 holes in the two F-830F-1 floor stiffeners that are common with the holes that attach the F-833D-1 rear seatback hinge
Clecoed the two F-830F-1 floor stiffeners in place on the F-830-1 and F-831-1 seat floor.
Match drilled #40 the keeper rivet hole into the F-830F-1 floor stiffener using the hole in the F-831-1 right seat floor as a guide
Final drilled the #40 the outboard most hole in booth F=830F-1 floor stiffener.
Clecoed the F-833D-1 rear seatback hinge in place on the F-830-1 and F-831-1 Seat floors.
Manufactured a shim from .025 aluminum sheet to place under the hinge common to the F-831-1 right seat floor and match drilled it to the rear seatback hinge #30.
Marking seatback hinge
Shim
Shim
