fabricated mounts to I can install whelles once the fuselage is flipped over
Page 8-39 Riveted the four bottom holes in each of the F-804H-1 centern section side plates and F-820 forward side skin Riveted the holes in the F-850-1 bottom skin Riveted the forward edge F-850-1 bottom skin to the F-802K-1 L.G. forward crossmember Riveted the F-802K-1 L.G. forward crossmember to the F-822-1 Forward floor Riveted the three holes in each of the F-802M-L-1 and R-1 intercostal rib that are common with the F-850-1 bottom skin
